I have some experience in several robots, however I never used profibus or setup a ABB, just programming in RAPID.
I need to change some module from a gripper and change to profibus they give me 2 modules Lumberg 970 PSL 700 16 DI/DO.
the older module was point to point.
The Configuration is PLC master Robot slave and IO Module of the gripper slave of the robot.
My questions are:
1) I need to use the second port in the DSQC 637 Profibus, do I need to mention in the configuration? By my understanding this is the port for the Master (robot is the master).
2) I'm trying to configure it but I had several problems with the configuration the Unit Type is not there, can i had one? How?
I read talking about the Softing configurator that generates a bin file from GSD. What ever I try it always complain about pbus_cfg.bin not found.
But a colleague told me should be possible to do it without it, because I only need to enable it. And that's where it starts my confusion because my colleague told me this should be done installing a new OS in the robot but with this enable.
>> products_id:
RobotWare Version: 5.15.9024.09
BRAKE-CHECK Version: 1.00.0000.00
RW Control module key
RobotWare OS and English
644-2 English
645-3 Spanish
709-x DeviceNet
709-1 master / slave single
711-1 PROFIBUS DP m / s
608-1 World Zones
611-1 Path Recovery
613-1 Collision Detection
614-1 FTP and NFS client
616-1 PC interface
RW Drive module 1 key
ABB standard manipulator
IRB 6640
Axis 1 standard work range
6640-185 / 2.8
No motor fan
Drive System 09 4600 / 66x0 / 460/660/760
No additional drive
