hello everyone ,
Does somebody know how to display the robot points in motosim?
I have a lot of points in a job and i would like to optimize the robot path , i need to see each one for improve the path .
cordially
hello everyone ,
cordially
From position panel ( see a picture) .You can exchange SLURBT in robot or base cartesian coordinates.
There are other way too,
you can go on each MOV line and press DIRECT OPEN key on the teach pendant.
thank you guy , but i would like to see all the point of my job , i learned around 100 points for controlled components of a motor truck.
For improve the path i need to see all of them , in order to place them in a chronological order .
doest it possible ?
Are you using MotoSim, MotoSim EG, or MotoSim EG-VRC. What software version?
This can more than likely be done, how depends on what software and version. Could be as easy as Controller tab, then Visual Path Edit.
I'm using Motosim EG VRC 2017
