KCL built-in procedure
  • leidai5
  • March 29, 2018 at 8:53 PM
  • leidai5
    43
    Good day,
    I'm trying to interpret some KAREL code and I'm having trouble understanding the purpose of the KCL built-in procedure. So for example, when would I use...
    KCL('SET VAR $RMT_MASTER = 1',STAT) ...as opposed to...
    SET_VAR(ENTRY, '*SYSTEM*', '$RMT_MASTER', 1, STAT) ...?
    Why would I want to execute a KCL command from a KAREL program?
    Thanks for your help.
  • notverycreative
    • May 6, 2021 at 2:32 AM
    KCL can be implemented outside of KAREL. You can build several lines of KCL code in a text editor and deploy as a .CM file for setting up common system variables, but you won't be able to set up as much stuff as you can with a KAREL file. For instance, you can't label your IO with KCL but you can with KAREL. You can run programs with KCL or KAREL from a Telnet session, or from a web browser though.
    KCL will let you write I/O and simulate ports, but you cannot read them, or I am not seeing how to do it. You also can't read or write to registers from what I have seen so far.
    It's kind of silly, but there might be some utility in there in some situations. I haven't got to play with it a whole lot.
  • pdl
    270
    1,541
    • May 6, 2021 at 6:04 PM
    KCL ABORT FORCE can be very useful. 😉
