Hello everyone, I wrote a configuration parameter file, independent. When backups are not backed up, how can you backup your own independent parameters?
parameter abb
- 硕江苏
Depending on your system (this is from an S4C controller)...
Under Misc>System Parameters the File pulldown should offer options:Code1. Load Saved PArameters... 2. Add New Parameters... 3. Add or Replace Parameters... -------------- 4. Save All as... 5. Save as... 6. Check Parameters Restart
We had some old S4's that did not backup system parameters - these files had to be saved separately.
I don't remember what reference I found this in, but you can try it. It didn't work for me but I think it is because it was a directory with a lot of files. Maybe it will work for you. Make a usersys.cfg file and put this in it:
SYS:CFG_1.0:6:0::
BACKUP_RESTORE-IncludeDirAtBackup "name of directory which has your custom parameters"
Then "ADD" this file, not delete or replace.
