add new Headstock
  • orkissos
  • March 25, 2018 at 3:28 PM
  • orkissos
    10
    if i want to add a new Headstock to my motoman dx 200 how i do it ?
  • 95devils
    234
    8
    1,947
    • March 25, 2018 at 8:07 PM
    Buy the equipment.
    Install the equipment.
    Setup the equipment in maintenance mode.
  • Robodoc
    56
    7
    1,059
    • March 25, 2018 at 8:57 PM
    The best thing woulf be to contact your Yaskwawa rep. There is a difference for the install if you want to do coordinated motion or not.
    Robodoc
  • orkissos
    10
    • March 26, 2018 at 5:39 AM
    yes i want to install with coordinated motion
    and how i do the setup on the dx 200?
  • 95devils
    234
    8
    1,947
    • March 26, 2018 at 11:43 AM
    Contact your local Yaskawa rep. Coordinated motion will need to be turned on.
  • orkissos
    10
    • March 26, 2018 at 2:04 PM
    how i connect to the controler and how i setup in the controler?
    if i want to connect pneomatic motor i can ?if yes how i do it
  • Robodoc
    56
    7
    1,059
    • March 26, 2018 at 11:38 PM
    You'll never be able to do coordinated motion with a pneumatic motor.
    If you don't need coordinated motion you'll have to hire an integrator to get the robot to control this.
    Robodoc
  • orkissos
    10
    • March 27, 2018 at 5:44 AM
    i want two thing
    to buy a Headstock whit coordinated motion from motoman and to install it by my self how i do it?(installing and play the motor form the dx 200)
    and to by a pneumatic motor and connect him to the dx 200 thet the dx give him 1/0 i cant do it?
  • Robodoc
    56
    7
    1,059
    • March 28, 2018 at 11:30 PM
    Short answer, no.
    You will need Yaskawa to turn parameters on.
    Robodoc
  • orkissos
    10
    • March 29, 2018 at 6:38 AM
    i find a manual for connecting servo motor to dx 100
    http://cdn2.hubspot.net/hubfs/366775/d…t=1468601845515
    it is good? and i go to axic i/o alloc
  • 95devils
    234
    8
    1,947
    • March 29, 2018 at 2:44 PM
    • #11
    No, that is a manual for a specific function.
    After purchasing and installing all the hardware.
    In maintenance mode, in management security or higher, go to SYSTEM, SETUP, CONTROL GROUP, S1 (assuming).
    Pick the type from the machine list.
    Choose which servo board the axis is going to use.
    Choose which axis is linked to the brakes.
    Choose the number of the convertor.
    Choose the ON_Enable signal.
    Choose the input of the overrun switch.
    Your axis type will be rotational since you said headstock.
    Choose the range of motion in the + direction.
    Choose the range of motion in the - direction.
    Set the numerator.
    Set the denominator.
    Choose the motor type.
    Choose the servo amp type.
    Choose the converter type.
    Set the rotational direction.
    Set the max rpm.
    Set the acceleration time.
    Set the inertia ration.
    Modify the control goup.
    If you need coordinated motion contact Yaskawa so they can turn it on.
    Then you need to set up control groups and calibrate the robot to the external axis.
  • orkissos
    10
    • April 8, 2018 at 7:49 AM
    • #12
    tank you
  • apakrat13
    72
    • March 12, 2023 at 11:44 AM
    • #13
    Hi Sir, I'm working with Gp7 and 1 S1: Turn-1 (SGM7G-13APK-YR1*/CSRA-SDB71HA). The motor run normal when I test with no payload but is not good when using payload. I guess that because my INERTIA RATIO setting is wrong. Would you please tell me how to set it? THanks for your help.
    Quote from 95devils
    Set the numerator.
    Set the max rpm.
  • 95devils
    234
    8
    1,947
    • March 12, 2023 at 7:01 PM
    • #14
    Quote from apakrat13
    Define “not good”. Chatter, hunting and pecking, dithering, alarms, etc.
    What is the payload? Weight, gearbox, etc.
    Did you set up according to motor nameplate?
