Is there a ascii file that we can edit with a txt editor? Does yaskawa have a manual for programming with a txt editor. Do we have to compile it into another format for the robot to read?
Are you trying to read a *.jbi file ? You should be able to open, edit and save back (as long as there are no typos) with any editor (notepad, wordpad ,etc, etc
Is there a manual that explains the format of the file. Example like fanuc .ls files have header, subcategories such as Begin/END/POS/ ect...
There is a header and formatting, I would start with a random job file and build from there. Also, there is a Notepad++ theme that will highlight the JBI command syntex
