KRC4 Compact IO wiring
  • AiSard
  • March 20, 2018 at 9:52 AM
  • AiSard
    44
    I want to use the robot IO to control a solenoid valve, we're using a KRC4 Compact.
    The default IO mapping for the EL1809 is already mapped and working (checked the lights when I fiddled with the outputs on the pad) but I'm unsure how to do the physical IO wiring.
    My solenoid valve has two wires, positive to go to one of the ports on the EL1809, while I understand the negative would go to the EL1100?
    But of the three negative ports on the EL1100, two connect to each other, and the last connects to X55 (which I vaguely recall got connected to itself (to close the circuit?) by the kuka guy when we were setting up the robot years ago.
    In this case where should I be plugging the wires in to?
    (sorry if I'm missing any information/context, very weak in terms of hardware :icon_frown:)
    tl;dr For my valve, where should I connect my negative wire?
    edit: added photo
    Images
      • 153.98 kB
      • 1,477 × 1,108
      • 119
    Files
    2311.jpg_thumb 40.83 kB – 324 Downloads
    Edited once, last by AiSard (March 20, 2018 at 10:02 AM).
  • Ayoub
    8
    28
    • March 20, 2018 at 11:38 AM
    EL2809 : 16 outputs 24V/0.5A
    EL1809 : 16 inputs 24V/3ms
    You have to use X12 interface instead of wiring directly on the beckhoff module.
    Connect the positive wire of the solenoid valve to one of the outputs and the second to a common ground, then you've to configure this output with WV to open and close the solenoid valve.
    Images
      • 24.97 kB
      • 570 × 289
      • 80
    Files
    azerty.PNG_thumb 12.17 kB – 379 Downloads
  • AiSard
    44
    • March 20, 2018 at 12:14 PM
    Is X12 the one with 30+ pin holes?
    Someone must've mixed the labels around as I've been thinking that was X69 all this time..
    (and was wondering why it didn't match up with the manuals...)
    But yes, I'm connecting to EL1809 through the 30+ pin hole interface, not directly.
    The common ground thing is the thing I was stumped on, but I've since figured out I can take it from X55 (right?) pins 6/8?
    The WV is already configured.
  • panic mode
    1,262
    13,027
    • March 20, 2018 at 1:45 PM
    if you are referring to X12 connector on the controller, that is 50-pole female connector and it has 50 contacts ("DB50F").
  • AiSard
    44
    • March 21, 2018 at 6:28 AM
    got the ground from X55, IO is working :icon_smile:
    would have gotten it sooner but had the pins for X12 mirrored (was stupidly looking at the labelled numbers rather than where the wires were actually going) :hammer1:
    Thanks for the info about X12 though
  • panic mode
    1,262
    13,027
    • March 21, 2018 at 1:13 PM
    contact numbers are written on the connector insert - next to each contact.
    for those without magnifying glass, here are pinouts for DB connecotrs.
    Images
      • 34.22 kB
      • 904 × 298
      • 125
    Files
    DB50 connector pinouts.jpg_thumb 10.26 kB – 292 Downloads
