How to clear messages which are made with MsgNotify("") command
  • RookieWithRobots
  • March 8, 2018 at 10:20 AM
  • RookieWithRobots
    76
    Hi there,
    I'm planning to show some messages to operator with MsgNotify("information text") command. And it works I can show some messages. But we are having quite complex work cycle and there are coming lot of these massages. So is there any way to clear that list without pressing that confirm all button from teach pendant?
  • Fubini
    282
    1,903
    • March 8, 2018 at 10:53 AM
    You could call
    CONFIRM 0
    inside your submit, whenever needed.
    Fubini
  • RookieWithRobots
    76
    • March 12, 2018 at 7:25 AM
    Hi there,
    Could you specify that little bit more? Im not totally following what and how that CONFIRM 0 should do and where.
  • RookieWithRobots
    76
    • March 13, 2018 at 10:20 PM
    Could anyone tell me little bit more about this CONFIRM 0 command? What it does and how I should use it.
    panic mode
    1,294
    13,126
    • March 13, 2018 at 10:28 PM
    try it...
  • RookieWithRobots
    76
    • March 13, 2018 at 10:59 PM
    I will....but the problem is that i dont have robot available right now. And i try to prepare my stuff before next visit to customer ar much as possible. I tried to search that CONFIRM command from Kuka manuals but havent found anything. Maybe I was searching for wrong ones so now this forum is the best place to found out.
  • davidina
    95
    • March 14, 2018 at 1:25 PM
    Quote from panic mode
    try it...
    I just tried it, but did not work. I think
    MsgQuit("this is a quit message", "myMod")
    should do
    panic mode
    1,294
    13,126
    • March 14, 2018 at 1:49 PM
    check topic name...
    btw i just tried it and it does not work
    Edited once, last by panic mode (March 14, 2018 at 2:01 PM).
  • RookieWithRobots
    76
    • March 15, 2018 at 3:35 PM
    I tried it and didn't get it work. PanicMode...could you tell me how this really should work ;=)
    panic mode
    1,294
    13,126
    • March 15, 2018 at 6:26 PM
    i don't know... it is an undocumented command.
    most messages end up in message buffer. there are functions to place message into buffer, remove message from buffer (that removes it from screen) etc. but buffer can hold only limited number of messages.
    notification messages are different... they are the only message type that is not managed in message buffer. so the only way to remove them from display is to manually acknowledge them. mentioned command was supposed to allows another way of getting them out of way but it did not work for me, may be depreciated etc.
