milling application for kuka 360-krc2
  • km427
  • March 3, 2018 at 1:04 PM
  • km427
    126
    Hello
    I have a kuka 360-krc2 with gripper (handling ) application , I want to use this kuka for milling .
    Can I use this kuka for milling with handling application?
    I write program with power milling software but when do you run program in Auto mode , I’m advertent wrong move in an axis Y .
    I’m define an axis Y and axis X move ten millimeters , axis X move correct but axis Y move incorrect
    ( about eleven millimeters or more move )
    Now that my circular change to oval . I guess the problem for an application
    What is it a different with handling application and milling application ?
    I need new application for milling work this kuka . how can I ready milling application for kuka ?
    How can I solve the problem ?
    Can you help me . :help:
    Best regards .
  • Aleks_Tarasov
    18
    • March 4, 2018 at 5:49 AM
    Hi, I haven't met with handling application but probably the mistake is a wrong calibration your milling tool or/and zero point. How did you do that?
    It might be useful to attach some program code and your table tools data
  • km427
    126
    • March 4, 2018 at 1:30 PM
    the Kuka master with ETM device and the zero point is correct , befor the start program in auto mode the first define new base then the start program .
    how can I make tool milling ?
    I need a new application . milling application .
    how can I bought milling application for a Kuka ?
    The windows installed the system is XP , with KRC 5.4.8
    Leon
    35
    5
    473
    • March 5, 2018 at 12:10 PM
    there is a lot here you need to explain a little better,
    first off to clarify you have a used robot that previously has been used for a handling application and you want to convert it to a milling robot. I presume you already took the gripper off and mounted a mill to the robot?
    The next thing you mention is that you use powermill to generate your milling program, i have never used powermill but if i am not mistaken powermill only generates cnc code which does not work on a robot. If you want to use powermill you will have to make sure that you can generate krl or can convert cnc to krl. Another option would be the CNC package from kuka. You will have to ask kuka themselves if that would work with your machine.
    No about your deviation in the y-axis, how did you measure this? and with what program? is this with a program you generated in powermill, or was this a program written on the pendant? did you check this multiple places in your available work area? if you rotate your tool around its point is there a deviation or does the point move?
  • robot-cnc
    432
    • March 7, 2018 at 11:49 AM
    Powermill can write in kRL language if has Robot Interface module.
    You should describe better what have you done.
