Hey guys,
I'm new to programming with Karel and need to modify an existing tech package for a 3D measurement system. The problem that I'm having is trying to build a file called getPath.KL that I wrote and when doing so I get errors that are listed for a file called iscom_CFG.KL(supplied by customer) that can build successfully. I even have the .pc file in the File tree.
What I don't understand is why the error path is the .KL file for iscom_cfg and why is it pointing to the iscom_cfg file which compiles without errors?
Is it possible to write PR[1]=PR[2] in Karel? So far I haven't found code/syntax for that?
will be much appreciated guys!
