Help understanding errors while compiling
  • ashwinmudigonda
  • February 22, 2018 at 7:20 PM
  • ashwinmudigonda
    43
    I am trying to write a TCP client in Karel to talk to a simple python server. I went through the manual and configured a client on $HOST_CFG[1]. I typed the example client from the manual into Notepad++(I couldn't copy paste)
    PROGRAM loopcl
    %STACKSIZE = 4000
    %NOLOCKGROUP
    %NOPAUSE=ERROR+COMMAND+TPENABLE
    %ENVIRONMENT uif
    %ENVIRONMENT sysdef
    %ENVIRONMENT kclop
    %ENVIRONMENT bynam
    %ENVIRONMENT fdev
    %ENVIRONMENT flbt
    %INCLUDE klevccdf
    %INCLUDE klevkeys
    %INCLUDE klevkmsk
    VAR
    	file_var : FILE
    	tmp_int	 : INTEGER
    	tmp_str  : STRING[128]
    	status	 : INTEGER
    	entry	 : INTEGER
    	loop1	 : BOOLEAN
    BEGIN
    	SET_FILE_ATR(file_var, ATR_IA)
    	SET_VAR(entry, '*SYSTEM*'. '$HOST_CFG[1].$SERVER_PORT',80000,status)
    	-- Connect the tag
    	WRITE('Connecting...',CR)
    	MSG_CONNECT('C1:',status)
    	WRITE(' Connect status = ',status,CR)
    	loop1 = TRUE
    	IF status = 0 THEN
    		WHILE loop1 = TRUE DO
    			WRITE('Opening file...',CR)
    			OPEN FILE file_var('rw','C1:')
    			status = IO_STATUS(file_var)
    			IF status = 0 THEN
    				FOR tmp_int = 1 TO 100 DO
    					tmp_str = '0123456789012345'
    					WRITE file_var(tmp_str::10)
    					WRITE('Wrote 126 bytes',CR)
    					IF status <> 0 THEN
    						WRITE('Loop test fails',CR)
    						loop1 = FALSE
    						tmp_int = 100
    					ELSE
    						WRITE('Read 126 bytes',CR)
    						READ file_var(tmp_str::10)
    						WRITE('Read status ', status,CR)
    					ENDIF
    				ENDFOR
    				WRITE('Closed file',CR)
    				CLOSE FILE file_var
    			ELSE
    				WRITE('Error opening file',CR)
    				loop1 = FALSE
    			ENDIF
    		ENDWHILE
    		WRITE('Disconnecting...',CR)
    		MSG_DISCO('C1:',status)
    		WRITE('Done.',CR)
    	ENDIF
    END loopcl
    We have HandlingPro evaluation version. I was able to load and compile simple programs. I tried to load the Karel_Client.ls program, and got error messages (see attached). I am not sure what they mean. Clicking on them does not help.
    Could someone point me in a direction on how to debug?
    Images
      • 22.02 kB
      • 1,276 × 378
      • 49
    Files
    2018_02_22_12_15_58_HandlingPRO_Evaluation_30_days_left_HandlingPRO1.png_thumb 4.57 kB – 86 Downloads
  • Go to Best Answer
  • ashwinmudigonda
    43
    • February 22, 2018 at 7:34 PM
    I tried to write a simpler hello world and got errors trying to load the program in HandlingPro.
    --hello_world.kl
    PROGRAM hello_world
    BEGIN
    	WRITE('Hello, world!',CR)
    END hello_world
    I tried following the instructions in this page - http://www.onerobotics.com/posts/2013/int…el-programming/
    i was able to compile the hello_world to a .pc file.
    I was able to find it on the pendant after copying it onto a USB drive and inserting it into the controller.
    However, when I choose LOAD, I get
    The KAREL option is required.
    When I check the STATUS, I do see
    KAREL Cmd. Language J650
    KAREL Run-Time Env J539
    on the pendant.
    Am I missing something?
    Images
      • 32.96 kB
      • 1,274 × 708
      • 39
    Files
    Untitled.png_thumb 7.84 kB – 85 Downloads
    Edited once, last by ashwinmudigonda (February 22, 2018 at 8:31 PM).
  • pdl
    270
    1,545
    • February 22, 2018 at 8:54 PM
    You need to have Karel installed.
    The options that you listed will only allow you to view Karel variables and positions, but will not allow you to execute a Karel program.
  • Nation
    Typical Robot Error
    552
    1,933
    • February 22, 2018 at 9:03 PM
    pdl is right. You need option R632, which is Karel. Also, since you are creating your own TCP/IP packets, you will need User Socket Messaging as well, option R648.
    Edited once, last by Nation (February 23, 2018 at 4:12 PM).
  • rf103
    18
    264
    • February 23, 2018 at 3:11 PM
    Nation: shouldn't that be R632?
    ashwinmudigonda: which controller is this? R-30iB?
  • Nation
    Typical Robot Error
    552
    1,933
    • February 23, 2018 at 4:13 PM
    Quote from rf103
    You are right. I had a typo. I've edited my post to display the correct info.
  • ashwinmudigonda
    43
    • February 24, 2018 at 5:38 PM
    Quote from rf103
    Yes. It is a R-30iB Plus.
    I got the FANUC rep to give us a PAC, but when I try to install in the CTRL START mode, I get OPTN-033 Image not backed up
  • ashwinmudigonda
    43
    • February 24, 2018 at 6:23 PM
    • Best Answer
    Never mind. I figured it out. The manuals from FANUC are bad.
    I had to choose the USB as the media source, and then follow the rep's steps to AUTH and INSTALL KAREL.
    Then I couldn't figure out how to get out CTRL START mode. Turns out I had to tap on the FCTN button and choose the cold start option.
    Hopefully this will help someone else flailing through these steps.
  • Azermath
    58
    • March 21, 2018 at 8:34 PM
    :help: does anyone know how to trigger Auto update in the Ctrl Start? i had to install and auth both my Camera and IRvision but i can't seem to get past this auto update.
