KRC4 io control via profinet to siemens 1214
  • Etke
  • February 21, 2018 at 2:41 PM
  • Etke
    5
    I have kuka robot KR8 and controler KRC4. Some time before support explained that we can use profinet protocol for input and output signals.
    We bought siemens s7 1214 plc controler for that. I have managed to make connection between krc4 and siemens 1214 (when i reconnect cable to x66 port, controller makes message "connection between PLC and KRC4KR restored" KSS11014.
    But however, i can not make input and output signal transfere via profinet.
    I mapped io in workvisual (io - profinet). But i think i am writing a bad program in tia portal.
    I tried using direct adresses, using "Put/Get" function blocks...
    Maybe someone could help me, give me an example, or tell what function block i should use?
    Images
      • 17.21 kB
      • 1,225 × 160
      • 75
    Files
    ce28f03335e3ecfd5bd7017379adf9a1.png_thumb 2.83 kB – 94 Downloads
    Edited once, last by Etke (February 21, 2018 at 2:46 PM).
  • panic mode
    1,262
    13,027
    • February 21, 2018 at 2:57 PM
    Do you have ProfiNet option?
    Is it installed? Did you configure IO in a work visual project?
  • Etke
    5
    • February 21, 2018 at 4:30 PM
    As i mentioned before, i have profinet , and i mapped at wov, i will attach another image of that..
    My siemens plc and kuka krc4 has profinet connection made already, but i do not know how should ladder code look at tia portal side for plc...
    Images
      • 78.86 kB
      • 1,572 × 670
      • 104
    Files
    57ed5c8fd354abcd780733a344cb22b7.png_thumb 8.35 kB – 92 Downloads
  • n0909
    104
    • February 21, 2018 at 10:13 PM
    Hi Etke,
    Please see if this document will assist you in any way.
    Regards
    n
    Files
    109482123_S7-1500_KUKA_mxAutomation_DOKU_v11_en.pdf 1.87 MB – 127 Downloads
  • Etke
    5
    • February 22, 2018 at 7:51 AM
    Hi, i have read that already, but this package is for s7 1500 models :thinking_face:
  • Etke
    5
    • March 4, 2018 at 1:58 PM
    so noone can help me ? :thinking_face:
  • panic mode
    1,262
    13,027
    • March 4, 2018 at 4:30 PM
    [size=1em]incorrect...
    being willing and able are two very different things. please read topic READ FIRST.
    you stated that:
    [/size]
    [size=1em]* you are asking for specifics ("my PLC is model xxx") but you don't provide the needed info such as network setup, mapping etc on both ends (please lookup "gigo principle"). you show small part of KRC setup but no PLC (what KSS, what version of PNET, what version of GSDMS, which node is master/slave, what are the network settings, etc etc etc.)[/size]
    [size=1em]* you have "communication" between PLC and KRC but you cannot transmit signals. no details such as roles of each node, addresses etc. [/size]
    [size=1em]* you state you try to use functions "Put/Get", not sure what that is and on which node was it[/size]
    [size=1em]* you are asking for PLC code help but ... this is a robot forum, not PLC forum. btw. writing code comes AFTER you have working connection (signals sent from PLC are read by KRC and the other way around).[/size]
    [size=1em]* All kuka tech packaged including ProfiNet some with manual. did you read it? what step exactly trips you?[/size]
    Edited once, last by panic mode (March 4, 2018 at 5:02 PM).
  • hermann
    403
    2,593
    • March 6, 2018 at 9:44 AM
    For the TIA configuration there shouldn't be a difference between the 1500 and 1214.
    You don't need to use put/get blocks. Just access the I/Os as normal I/O. Somethin like ----|I1.0|------|I1.1|-------------(O1.0)
  • fatima
    22
    • June 27, 2018 at 3:04 AM
    Quote from Etke
    I have the same problem right now ... Have you found the solution?
