read string data from csv- karel
  • vipinpunneri
  • February 19, 2018 at 4:59 AM
  • vipinpunneri
    137
    hello friends
    i was trying to make a program for reading data from csv..
    my data will be like LWP15452,145 i need to read LWP15452 and 145 seperate.. in present i can able to read the entire line ..
    pls help
    thanks
    vipin
    Thanks regards<br />Vipin..
  • inusO
    33
    • February 19, 2018 at 9:21 AM
    is the number of characters always the same? If so, you can just use the built-in function SUB_STR(source_string , start, len) that return a substring of source_string starting from start character and takes up to len characters
    An example would be:
    first_part : STRING[8]
    second_part : STRING[3]
    first_part = SUB_STR(full_line, 1, 8)
    second_part = SUB_STR(full_line, 10, 3)
  • vipinpunneri
    137
    • February 19, 2018 at 10:09 AM
    Quote from inusO
    hi...
    thanks for that, but number of characters is not same in my case...
  • inusO
    33
    • February 19, 2018 at 10:30 AM
    The standard way would be to use regular expression, but as far as I know there isn't support in Karel.
    A workaround here would be to use some IF clauses and the built-in function STR_LEN to identify how your string is structured or maybe check where the ',' is, that depends on the format of your string.
    Once you have to correct lengths you can use SUB_STR as I shown
  • skalactik
    13
    111
    • February 19, 2018 at 11:05 AM
    Maybe use loops to read each character of the string until any ",' shows up then split the string.
  • vipinpunneri
    137
    • February 19, 2018 at 11:25 AM
    Quote from skalactik
    How?? i have checked formatting string data, ::0::2 by using this i can able to separate string with quotes not with comma..........
  • inusO
    33
    • February 19, 2018 at 11:54 AM
    This will probably do
    first_part = ""
    second_part = ""
    change_part = FALSE
    FOR i=1 TO STR_LEN(full_line) DO
      current_character = SUB_STR(full_line, i, 1)
      IF current_character <> ',' THEN
        IF NOT change_part THEN
          first_part = first_part + current_character
        ELSE
          second_part = second_part + current_character
        ENDIF
      ELSE
        change_part = TRUE
      ENDIF
    ENDFOR
  • vipinpunneri
    137
    • February 19, 2018 at 12:49 PM
    Quote from inusO
    first_part = ""
    second_part = ""
    change_part = FALSE
        ELSE
        ENDIF
      ELSE
        change_part = TRUE
      ENDIF
    ENDFOR
    Hi..
    great this is working.... thanks
