Karel syntax highlighting for Sublime 3
  • Hello everyone,
    since I use Sublime 3 as editor, I wrote a simple custom syntax file to highlight Karel programs and I thought to share it;
    Other than setting different colors to language elements it also allows for quick jumps to ROUTINE declarations within project either by click or Command Palette
    In order to use it you have to place it in C:\Users\<your_username>\AppData\Roaming\Sublime Text 3\Packages\User and then apply it from Sublime by bringing up the Command Palette (ctrl + shift + P) and then select Set Syntax: karel (typing 'syka' in the command palette will do)
    If you find anything wrong or something that needs to be changed feel free to ask here or edit it by yourself
