hi, everybody!!
i have IRC5compact and Irb1200
i want configurate Profinet,to connect to PLC S-7 Siemens
is anybody know the way to ippnio.xml file?
I read manual of "Profinet controller/device" but don't understand where is the "ippnio.xml" file.
IRC5 compact ippnio.xml
mr_ruslan -
February 12, 2018 at 11:54 AM -
Thread is Resolved
The ippnio.xml file is generated during the profinet configuration activity. It is loaded to the robot harddrive, and the robot is told where to go to read the file. The file is used to configure the profinet network. I've tried editing the ippnio.xml file in a text editor before, but found it difficult. My recommendation is to use the profinet configurator program that comes on the robot DVD (in the utilities folder), and generate a new ippnio.xml file.
hi, everybody!!
I read manual of "Profinet controller/device" but don't understand where is the "ippnio.xml" file.ippnio.xml file created in the Profinet document as an example. You don't have to use it. You can create this file using the Profinet I/O Configurator Express which is located in the RobotWare Tools And Utilities. This file generally downloads with robot studio. Find it in the fieldbus directory and install and follow the manuel's instruction. If robot is going to be master (Or controller) and others as slave, follow the Configuring the internal controller and external device instruction. If this situation is opposite, follow the Configuring the internal device and external controller instructions.
