Help with Karel code
  • So I want to set a variable from a TP program but my problem is the Variable name is too long to use the $...=.... instruction.
    So I found this Karel code that seems to be working
    PROGRAM SET_INI_OFS
    VAR
    ENTRY:INTEGER
    STATUS:INTEGER
    BEGIN
    SET_VAR(entry, '*SYSTEM*', '$DPM_SCH[1].$GRP[1].$OFS[1].$INI_OFS', 10.0, STATUS)
    END SET_INI_OFS
    However instead of changing the variable to 10.0 I want to reference a register.
    I'm trying to use the Karel reference manual to figure it out but i have never used Karel before so I'm not getting very far.
    Can someone show me the code I need to do this?
  • 1. declare a new REAL variable (let's name it value)
    2. before your SET_VAR: read the register (GET_REG built-in? don't remember the built-in names and don't have the manual at hand atm.), saving it to value
    3. change you SET_VAR to:
    SET_VAR(entry, '*SYSTEM*', '$DPM_SCH[1].$GRP[1].$OFS[1].$INI_OFS', value, STATUS)
    The program will now read the register and save it to the variable (as REAL), and then use this variable to set the system variable that you wish.
    EDIT: to make it neater, I would also add some evaluation of STATUS - at least a check against a non-zero value.
    Edited once, last by bidzej ().
  • PROGRAM SET_INI_OF2
    VAR
    ENTRY:INTEGER
    STATUS:INTEGER
    REGISTER:INTEGER
    RFLAG:BOOLEAN
    RVALUE:REAL
    BEGIN
    GET_REG(150,RFLAG,REGISTER,RVALUE,STATUS)
    SET_VAR(entry, '*SYSTEM*', '$DPM_SCH[1].$GRP[1].$BI_CH[1].$BUMP_RATE', RVALUE, STATUS)
    END SET_INI_OF2
    OK I think that is what I did. What I was having trouble with is for some reason I thought the variable that "GET_REG" stored to was the "REGISTER:INTEGER" variable.
    Then I found that in order to get the above code to work you had to have a decimal number in the register. 10.1 will work, but 10 will not.
    Can you explain why if behaves like this? whats the difference/significance between "REGISTER:INTEGER" and "RVALUE:REAL" in the GET_REG line.
    The manual says
    • RFLAG is set to TRUE and RVALUE to the register content if the specified register has a real
    value. Otherwise, RFLAG is set to FALSE and REGISTER is set to the contents of the register.
    I understand that as: If the value is a integer store the result in REGISTER if its a real number store it in RVALUE. but when I enter a integer number in the register and use REGISTER in the SET_VAR line it doesn't work.
  • There is a good explanation of this issue somewhere on this forum - search for it :smiling_face:
    This is what I've found in the manual (R-30iA/iB):
    So, to avoid such problems, you can do the following:
    1. after using GET_REG, evaluate the real_flag to check if the value read from the register is REAL or INTEGER (with an IF).
    2. if real_flag is false, read the int_value and convert it to REAL, saving it to your RVALUE. I don't see a built-in which can be directly used for int-to-real conversion, so I would try adding 0.0 to int_value...
  • 2. if real_flag is false, read the int_value and convert it to REAL, saving it to your RVALUE. I don't see a built-in which can be directly used for int-to-real conversion, so I would try adding 0.0 to int_value...
    You can just directly assign an int to a real, and vic versa (although going from real to int truncates the real). Also, reals can contain larger values than ints, so you have to watch out for that.
