Hello Guys, I'm setting up a KR C2 edition 2005 to read analog input.
I'm a new and I'm experiencing some problem to get the correct value from the input.
The controller has a WAGO 750-346 DeviceNet ECO FieldBus Coupler attached with 4 IO modules resulting in a 32 IO A/D interfaces.
I've read the manuals and I have setup the configuration file IOSYS.INI like this:
[DEVNET]
; Devicenet MACID 5
ANIN1=5,0,16,1,CAL1
If I send a 0-10V direct current to the analog input 1 (using a DV current generator) I can observe two things:
1- The led on the Module glows changing it's luminosity as the current changes (by manipulating the current generator trigger, i.e. the current actually flows WAGO module)
2- The value of the $ANIN[1] (observed by the "watch variable function" as like as the "analog display" variable of the "analog input/output view function") changes passing ISTANTLY from 0 to 10 (Volts since CAL1 is normalised as so) when the current I pass as input actually passes the threshold of ~9.0V (instead of gradually change from 0 to 10 through all the intermediate values)
Any Ideas about this strange behaviour?
Note: I've tried to change EVERY parameter of the config string and studied all parameters.
- changing the justification
- changing the resolution
- changing the CAL value
- changing the offset
- changing the port (ANIN1,2,3)
- I also commented out all other useless settings in the config files leaving only the minimal setup:
i.e.
[CONFIG]
;.. other drivers
DEVNET=2,dnInit,dn2drv.o
;.. other drivers
[SECTIONX]
; commented out config params
[DEVNET]
; Devicenet MACID 5 (the only one I use)
ANIN1=5,0,16,1,CAL1
[SECTIONY]
