Hi! Like every robot during a movement the cursor of the program continue going forward for a number of brogramming raws and execute some logic statements. Is there a way to stop the cursor if needed? I know the "with condition" statement using "when at end do" but you can not put in there many things like an IF statement...
PREVENT CURSOR TO GO FORWARD DURING MOVEMENTS
- IlFincoITA
Hello
You mean in automatic run like hold command or in manual? -
Hi! Yes during automatic or remote. I want to prevent the program from issuing some outputs or case statements to be performed during a robot movement
So if you want to stop the program always on the desired line, use the HOLD command.
I don't really know ... I just kept adding more commands when I felt like I wanted something specific to be more convenient and removed/replaced the ones that I rarely used.
I assume that you have a MOVE .. ADVANCE. Without ADVANCE the cursor does not forward until the motion has completed
Hi! Like every robot during a movement the cursor of the program continue going forward for a number of brogramming raws and execute some logic statements. Is there a way to stop the cursor if needed? I know the "with condition" statement using "when at end do" but you can not put in there many things like an IF statement...Not clear what you want to do. Cursor move to facilitate typing when you select a statement from menu in IDE.
Sent from my iPhone using Tapatalk
