Task does not exist...
  • nerd484
  • January 17, 2018 at 5:29 PM
  • nerd484
    21
    is there a way to check if a task exists?
    I have a karel program that calls a Run_Task on a teach pendant program to execute a move on a position register. Sometimes that position may hit an axis limit and error out. If that happens the teach pendant program pauses, and will prevent subsequent calls for run_task from complete since the first instance is still 'executing' but at a paused status. To get around this, i check to see an error has occured. If an error has occured i check to see if the task has been paused using the Get_tsk_info function. If the task is pasused then i abort it, so that the subsequent calls will work. The caveat with this is that, if i have yet to request a motion command, and i receive an error the get_tsk_info will be invoked; but, since i haven't created the task yet, i will receive another error stating that it cannot find the specified task. So, is there a way to check if a task exists before calling get_tsk_info?? Thanks!
  • skalactik
    13
    111
    • January 17, 2018 at 7:12 PM
    Why not check if any error affect the robot with a CONDITION ERROR[*] statement instead ?
    Also you already have the answer : if the get_tsk_infos return an error (STATUS) then the task doesn't exist.
  • moln4r
    128
    • January 18, 2018 at 5:15 PM
    I know it's not always that simple, but it's not possible to check the PR not to exceed the limit of the axis?For example in bg logic.
    Edited once, last by moln4r (January 19, 2018 at 7:37 AM).
