Another newb question here. I want to palletize some parts by utilizing the Tool Offset function to change the Z value on my Tool Frame. Very new to this and I see that I can use a Position Register to offset that location, for example I want to move the Z by 50mm, then on the next attempt by 100mm, then 150, etc.
What is the best method for changing the Z offset value by 50mm each cycle and then reset to 0 once the pallet is full??
I don't see an easy way to access the Z portion of the position register alone.
Thank you so much for all of the help.
