Help with Syntax Error 3110 DX controller
  • JYJ
  • December 12, 2017 at 5:38 AM
  • 95devils
    231
    8
    1,945
    • February 14, 2025 at 2:03 PM
    • #21
    Quote from cosmos_1
    When I'm trying to upload the job file, I'm getting Error 3230 -> system not matched. I've mentioned my job file below. Can anyone help me ?
    /JOB
    //NAME JOB1
    //POS
    ///NPOS 0,0,0,6,0,0
    ///TOO
    NOP
    GETS PX001 $PX001
    GETS PX002 $PX001
    END
    The number of robot position variables used isn’t 6.
  • 95devils
    231
    8
    1,945
    • February 14, 2025 at 2:10 PM
    • #22
    Quote from BMGN01
    1) Why are you using the GETS function before setting all the elements anyway?
    Probably to ensure: A) The position variable is formatted. B) It’s in the correct tool.
    2). By using $Px001 it is the correct XYZ format. Sure it won’t work in pulse because $Px001 is Base frame.
    Have never run into the date/time having to be the save. I dump jobs from other generations that I have modified into other or the same controller.
  • cosmos_1
    14
    • February 15, 2025 at 5:32 AM
    • #23
    Quote from 95devils
    I've uploaded the same file in our previous yrc1000 controller. But when I use the same file to upload in another controller, I'm getting this error. The difference between those controllers is one has external axis as station and other one has base. But I'm not using any of those control group in code, bcoz I dont want to use those external axis while performing job operation. I'm not able figure out the reason for the error.
  • Robodoc
    56
    7
    1,059
    • February 15, 2025 at 2:39 PM
    • #24
    Here is something you have to keep in mind when offline editing.
    If you open a job in Notepad and cursor down to the 'END' command you can cursor down ONE line below the 'END'. If you backspace this line out or don't have it (so the cursor ends up beside the D in END) the job will not load into a controller.
    Also if you can cursor down more than one line after 'END' it will not load.
    Robodoc
  • YakawFaBB
    72
    • February 17, 2025 at 8:56 AM
    • #25
    Hi cosmos_1
    Try this file below or verify i the robot have the same setup in other program ///GROUP1 RB1 :
    /JOB
    //NAME JOB1
    //POS
    ///NPOS 0,0,0,6,0,0
    ///TOOL 0
    ///POSTYPE BASE
    ///RECTAN
    ///RCONF 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    //INST
    ///DATE 2025/02/08 07:33
    ///ATTR SC,RW
    ///GROUP1 RB1
    NOP
    GETS PX001 $PX001
    SETE P001 (1) 0
    SETE P001 (2) 0
    SETE P001 (3) -500000
    SETE P001 (4) 0
    SETE P001 (5) 0
    SETE P001 (6) 0
    IMOV P001 V=50.0 SRCH RIN#(1)=OFF DIS=0.1
    SETE P001 (3) 30000
    IMOV P001 V=50.0
    SETE P001 (3) 0
    SETE P001 (2) -500000
    TIMER T=2.00
    GETS PX002 $PX001
    GETE D004 P002 (2)
    END
  • cosmos_1
    14
    • February 20, 2025 at 6:23 AM
    • #26
    Quote from YakawFaBB
    Hi cosmos_1
    /JOB
    //NAME JOB1
    //POS
    ///NPOS 0,0,0,6,0,0
    ///TOOL 0
    ///POSTYPE BASE
    ///RECTAN
    //INST
    ///ATTR SC,RW
    ///GROUP1 RB1
    NOP
    GETS PX001 $PX001
    SETE P001 (1) 0
    SETE P001 (2) 0
    SETE P001 (4) 0
    SETE P001 (5) 0
    SETE P001 (6) 0
    SETE P001 (3) 30000
    IMOV P001 V=50.0
    SETE P001 (3) 0
    TIMER T=2.00
    GETS PX002 $PX001
    GETE D004 P002 (2)
    END
    I have tried this file, but I'm getting system not matched error.
  • YakawFaBB
    72
    • February 20, 2025 at 10:18 AM
    • #27
    Hi cosmos_1
    Quote from cosmos_1
    I tried your program on DX200 it working fine. Send me cmos i can check on motosim.
  • cosmos_1
    14
    • February 20, 2025 at 11:17 AM
    • #28
    Hi cosmos_1
    I've uploaded the same file in our previous yrc1000 controller. But when I use the same file to upload in another controller, I'm getting this error. The difference between those controllers is one has external axis as station and other one has base. But I'm not using any of those control group in code, bcoz I dont want to use those external axis while performing job operation. I'm not able figure out the reason for the error. And one more thing is the controller which has external axis as station if i add another axis as base , then I'm not able to upload job file. From this I can see that if I add base axis, then I'm not able to upload job file. Can anyone help me understand this ?
  • potis
    245
    • February 21, 2025 at 2:42 PM
    • #29
    is the search function enabled in the controller?
