arc enable enabled through teach pendant
  • brian.b
  • December 7, 2017 at 6:37 PM
  • brian.b
    7
    49
    I want to enable the weld when the teach pendant is turned off. I have operators turning the weld off to manually run through the program and then forget to turn it back on. What steps can I do to fix this issue.
    Thanks in advance!
    r30ib
    100ic Fanuc arm
  • keyboard7
    162
    • December 7, 2017 at 9:28 PM
    The teach pendant does not have to be turned on to enable the weld, just hold shift and hit weld enable. You dont have to turn it on to get to 100% either.
    I tell the operators to never turn the teach pendant on, It is also in our work instructions for operators. Operators with the teach pendant on can cause some terrible things.
  • vipinpunneri
    137
    • December 8, 2017 at 11:56 AM
    try to make BG Logic operation.... use this system variable to make this happen $AWEPOR[1].$ARC_ENABLE, if the value is 1 ARC is enabled.. just make program by this kind of logic, if the tp is turned off the above variable should turned as 1
    ex:
    $AWEPOR[1].$ARC_ENABLE=(!SO[7:TP enabled]) ;
    Thanks regards<br />Vipin..
    Edited once, last by vipinpunneri (December 8, 2017 at 11:59 AM).
  • beanluke
    32
    • December 8, 2017 at 5:40 PM
    You can also map a digital input to weld enable. So for example if the cell is in "auto" or "production mode" the PLC will turn on the DI forcing weld enable on.
  • brian.b
    7
    49
    • December 8, 2017 at 8:28 PM
    If anyone is curious, this is what I came up with to run in my BG Logic...
    1: IF (SO[7:TP enabled]=OFF) THEN
    2: $AWEPOR[1].$ARC_ENABLE=1
    3: ENDIF
    I can enable/disable my weld when the teach pendant is on. If my weld is disabled and I turn the teach pendant off, the weld will instantly turn the weld back on. The same can be applied to speed as well when using that variable too. This can be added too with a little tweaking to fit your personal setup.
    Something simple but it helps...
  • Shubham Malhotra
    22
    • January 14, 2025 at 12:38 AM
    What to do if your
    is write protected.
    I am using SKS as the welder with FANUC R1000, R30iB
  • ssaul
    8
    54
    • January 17, 2025 at 7:40 AM
    Quote from Shubham Malhotra
    What to do if your
    is write protected.
    it does not metter that the variable is protected, if you run the program it will change it
