Hi there,
I am trying to run a hand guiding in auto mode for the first time, so I have created
ESM with one row - hand guiding device inactive and set enabling switch MF Touch = true
in a safety configuration. (according to the manual)
After synchronizing of project and restarting robot and activate new safety conf. with added ESM state,
I can't run any application. (When I set T1 or T2 mode, the enabling switch on the smartPAD
does not respond to the press and in AUT mode the play button does not start the application - in both cases
motion is denied). There is no error, Safety is ok - green light, but motion is denied. The only thing that works is hand guiding in T1, T2 mode (without a program)
If I remove the ESM state, everything is running well again. In the Annex I add screenshots of my safety configuration.
EDIT: There are some errors in a protocol:
- Generic device error
- position invalid (ID1,...,ID7)
- Axis range data ID1,...,ID7 invalid
- Axis range ID1,...,ID7 unknow
But after activation safety conf. there are only one warning (positions sensor not referenced)
does anyone know how to fix it?
(LBR iiwa 7 R800/Touch pneumatisch)
I will be happy for any advice
Marhy
