Line Tracking, help pls
  • slamcity
  • December 1, 2017 at 7:19 PM
  • slamcity
    40
    Hi Guys,
    I'm trying to setup a line tracking program.
    I select tracking program, hit detail, hit next button 2 times to get me to the "line Track Program Header" screen.
    Now on this screen I have these:
    1 Line track schedule Number: 0
    2 Continue track at prog end: True
    3 selected boundary: 0
    From what I read in the manual, I have to change it to this:
    1 Line track schedule Number: 1
    2 Continue track at prog end: False
    3 selected boundary: 1
    The problem I'm having, is when I change these settings. When I exit the screen, and come back in to it, the settings are back to default(see below). Like it wont accept the changes.
    Any ideas on how to make it stay with the settings I put in?
  • cobenson
    10
    314
    • December 3, 2017 at 1:31 PM
    Did you power cycle? Anytime changes are made, you must power cycle or the changes don't take effect.
  • slamcity
    40
    • December 4, 2017 at 1:23 PM
    yes, I have.
    Numerous times.
  • Presto
    8
    • December 4, 2017 at 10:16 PM
    What version controller and software are you using? If you already have a tracking program in the controller just copy it to a new name and delete everything in it - that way the header information will be there... just a temp work around. You should be able to create a new one from scratch though.
  • Leonidas
    13
    • December 9, 2019 at 5:28 PM
    Line Tracking Schedule #0 means you are not using line tracking.
    Setup Line tracking schedule #1 then go back into your header and change it to schedule #1
  • Phil2401
    7
    • December 9, 2019 at 10:11 PM
    Have you set up the up and down stream boundary values in the schedules.
  • Racermike123
    14
    901
    • December 10, 2019 at 12:25 AM
    Delete your program and recreate it. You can't add line tracking to a program that was not created with line tracking in it.
