Hi guys,
I'm trying to install a K-ROSET 1.8 in a Windows10 pc. I can do the installation correctly but when I start the program rises the following error: LoadLibrary failed with error 114 ( I attached a screenshot).
Any suggestion?
Hi guys,
Any suggestion?
This error is from Windows. Unfortunately, i don't have Windows 10 in order to test. Please have a quick search on google about
LoadLibrary failed with error 114. You will find a solution for sure
If you do a search for this error, you will see many of the resolutions refer to 'switching dynamic graphic options' within the Power Options in Windows 10 (something to do with windows 10 not being able to process the application graphics requirement properly).
I have never had this issue with 2 of my Windows 10 Pro installations (1 on an old workstation and 1 as a virtual machine).........so I could only recommend the above 'switching dynamic graphic options' as a first place to start.
many thanks for the suggestion.
This is the link that I have used to solve the problem:
https://steamcommunity.com/app/396890/dis…04254445517420/
It works!!
Very good. Good luck with the projects în KROSET.
