  3. Cobot Help and Discussion Center
  4. ABB YuMi
Abb YuMi Cobot CRobT in a proc problems
  • racido123
  • November 23, 2017 at 11:46 AM
  • racido123
    8
    i'm using the ABB YuMi cobot for a small project.
    i'm trying to create a function where the actual position of the cobot is stored in a robtarget.
    to use the robtargets later to create a path. Only when i use my created function it gives an error that i that it's an dummy positions. because it is empty
    but when i use the function directly it works fine.
    see code below:
    Proc Main()
    SetLeadthrough \on;
    TPReadFK reg1,"Press Apply to apply the coördinates", "Apply", stEmpty, stEmpty,stEmpty, stEmpty;
    if reg1 = 1 THEN
    TPErase;
    Pos1:= CRobT(\Tool:=Servo \wObj:= wobj0);
    Setleadthrough \off;
    reg1:=0;
    TPWrite "coördinates applied";
    ENDIF
    MoveJ HomePos, v200,fine,Servo;
    MoveJ Pos1, v200,fine,Servo;
    ENDPROC
    in this case it works fine but when i use in the as below it doesn't work
    PROC Main()
    TeachPos(Pos1);
    PROC TeachPos(robtarget pos)
    SetLeadthrough \on;
    if reg1 = 1 THEN
    TPErase;
    pos:= CRobT(\Tool:=Servo \wObj:= wobj0);
    reg1:=0;
    ENDIF
    ENDPROC
    ENDPROC
    Does some one know what i do wrong ? or what the problem is ?
    Edited once, last by racido123 (November 23, 2017 at 12:17 PM).
  • racido123
    8
    • November 23, 2017 at 2:32 PM
    i already found the problem.
    It needed to be a FUNC instead of a PROC because you need a RETURN
    :uglyhammer2:
    :wallbash:
