3 robots on thesame 7 axis
  • maxwell
  • November 14, 2017 at 7:23 PM
  • maxwell
    36
    HAllo guys i have an urgent issue am fighting with
    IM working with 3 krc4 robots on thesame 7 axis
    the Problem is the middle Robot doesnt have a safe home
    But im planning on sending an Output Signal to the sps anytime the Robot is in a central Position that is not safe so that the sps knows where the Robot is and will not send the other robots to the middle robots Position
    i tried making a logic on the sps Sub to Keep track of the 7 axis but ist just not working what im i doing wrong here
    IF ($POS_ACT.E1==-1600) THEN
    $OUT[230]=TRUE
    ELSE
    $OUT[230]=FALSE
    ENDIF
  • scotty
    43
    5
    497
    • November 14, 2017 at 7:48 PM
    are you receiving any data from $POS_ACT.E1?
    if you are getting something, then I would recommend to use ranges instead of fixed single value. as you maybe aware robot wouldn't never reach 1600.00 it will be ±0.02(depends on ...)
    So try to make range like:
    IF (($POS_ACT.E1>-1601.00) and ($POS_ACT.E1 < -1599.00)) THEN
    $OUT[230]=TRUE
    ELSE
    $OUT[230]=FALSE
    ENDIF
    Upd: Again, ... play with range.
  • hermann
    404
    2,595
    • November 14, 2017 at 9:08 PM
    And use $Axis_act instead of $pos_act. $pos_act sometimes has no value (after program reset, power up ...)
    Edit: Or You can use axworkspaces to set a specific signal. That should be the better solution, because that signal is handled by the system.
    Edited once, last by hermann (November 14, 2017 at 9:11 PM).
  • maxwell
    36
    • November 14, 2017 at 9:22 PM
    the idea with the axisWorkspace Sounds good
    can i influence the exact Output that has to be sent to the sps ?
  • scotty
    43
    5
    497
    • November 14, 2017 at 9:46 PM
    You can track axwork statuses by $AXWORKSTATE[1..8]
    SkyeFire
    1,039
    9,380
    • November 15, 2017 at 3:30 PM
    Quote from maxwell
    Yes. This is documented in the manual. The Cartesian and Axis Workspaces can be be configured geometrically, and for which signals they are linked to, as well as whether those signals indicate Inside or Outside.
  • maxwell
    36
    • November 15, 2017 at 7:05 PM
    Thanks very much guys for the help
    The $Axworkstate method worked very fine !!
