Hi
I am an amateur programmer.Please learn step by step offline programming stage for KR360 L280 KUKA Robot with KRC2 controller by Powermill 2017 software and run it with robot.
THK
offline programing
Moriii6530 -
November 12, 2017 at 10:11 AM -
Thread is Resolved
First of all you need to know working with Powermill CAM, to import your model and then to generate milling strategy, toolpath , feed rate, stepover, depth,...
You need to have robot interface of Powermill and to be able to configure your robot in machine library of PM. You need to configure all milling cell, spindle, rotary table excatly as it is in real space in your workshop.
Here you will program, simulate and postprocess output file with src extensions necessary for Kuka robot language KRL.
These files will need to be uploaded in robot PC with help of an USB stick (is most simple(), and copy them in R1/Program where robot will read and execute them.
If you are newbie there many to learn and will take a while.
Do you have your robot KR 360 configured already in Powermill Robot Interface ?
What you know at this moment? -
Hi
Thank you for your help.
I did all of stages and configure the robot.The .SRC file created by KRL post processor and copied in program folder.But the robot don't run it and it has some errors for example one of the errors says speed of A1 is not specified.
I attach the files for you.Please consider them and show the faults for me.
Thank so much...
Hello
Try with another postprocessor, I use the same as the picture.With experience I know that there is often a problem with giving the direction of the tool ,This is the angle of attachment of the tool A B and C .
You can upload a photo, how do you have a tool attached?Write what you have data in the tool.
A1 speed will not be specified in postprocessed file src. If the error reffer to A1 speed you should check machine.dat folder and check don't miss a line the one where is defined speed of motor from A1.
I don't think is a matter of postprocessing in Powermill.
Can you move the robot in T1 mode by jogging ? That error appear only when try to run src file you have? -
Well, there is no BAS initialization call at the top of the program -- there's only $VEL.CP settings, followed by E6POS motions. I suspect the "A1 Velocity" issue would be fixable by simply adding a stock "INI" fold at the top of the program, or by calling the module from, say, CELL.SRC.
Thank you all
Hello
I succeeded to copy all files into PRGM folder without any errors.But an error occurred at the start of PRGM.Please see attachments and guide me.
Thankful
Programs's files:
No INI at top of program.
Hi
I changed S and T parameters and ran program.But the robot does the wrong motion.Is the Tool/Base configuration has a wrong?
Probably yes. How do you have a tool attached to a robot? What data do you have after measuring in a robot? Please take a screenshot in the powermill as the tool is attached.
...what, exactly, is "wrong motion"? S&T do not change the final location and orientation of the TCP, only which axis configuration (wrist flipped or not, for example) the robot chooses from the multiple valid axis-space solutions for the Cartesian coordinates.
Hello my friend your problem i believe are the angles of the tool a0,b0 and c0. your robot had a tool, torch or spindle, the tool need orientation, powermill give the first ptp also ptp a1,a2,a3... change for this values and review the position if is correctly the tool orientation is bad.
Best regards
