Hi
i have a brandnew Controller here R30iB with "External mode select" option and have a problem with the UOP output "Cmd enabled"
in Automatic the Cmd enabled only gets high when i press shift+reset and only stays high as long i keep shift pressed.
when i release shift i get the message "SYST-301 External mode select not available" wich i allready changed from error to notification.
at the moment i can only run in auto if i keep shift pressed
does someone has an idea what it could be?
its probably one little setting that i forgot.
Loipe
