Is there a way to test for the presence of a stored position in a POSE file? For instance, I want to know if P[3] is stored in P1000.
Test for position stored in POSE file
jstolaruk -
November 8, 2017 at 10:26 PM -
You will need to store Zero value in P[3], like P[3]=(0,0,0,0,0,0)
You can then maybe have Program like below
REM "Pose File"
DIM Prog1000_posn[3] As POSITION
L1% = 0
USE 1000
*CONTINUE
L1% = L1%+1
POSE2POS 0,P[L1%],Prog1000_posn[L1%],0,1
OPEPOSE 0,P[L1%],V1!,1,0
IF V1!<0 THEN *STOP ELSE *CONTINUE
*STOP
STOP -
Thanks, but I can't see how this gets what I was looking for.
As an example, lets say file 1000 has the points P[1], P[5], P[10] in it.
If I play this:
USE 1000
LET P1001, P[1]
LET P1001, P[5]
LET P1001, P[10]
....everything works fine because the points exist in file 1000
But If I play this:
USE 1000
LET P1001, P[3]the robot gets stuck and hangs up on the LET statement. It doesn't even cause an error as far as I can tell. So it would be nice to know if P[3] actually exists before trying to use it.
Wouldn't the POSE2POS statement hang also?
( this is an FD11 controller )
What is Function Number used for LET P1001,P[1]
Yes,Controller does not like if a Pose is called for, which has not been defined
FN634 is LET
