Hi!
I need to check speed of robot axis with TestSignRead but in the manual only signals for external axes are given.
Does anybody know how can I get numbers of signals and channels for all of six axes?
Test signals for the robot axes
- WojciechL
I haven't tried this out in production so test at own risk but I believe you just have to specify name of the unit and define the axis, so you would have to set up 6 TestSignDefine for each axis
In the manual replace the mechanical unit name with the robot unit to get the joint reference - it'll most likely be ROB_1 unless it's been re-named.
I use this reference for resetting axis values like a rotary mechanical unit ie:
IndReset ROB_1,6\RefNum:=0\Short;
Thanks.
I found number of test signal for axis speed (it's 4001) but it works only with Robotware 6.05. And I have a robot with Robotware 6.01.
I tested it with Test Signal Viewer and in RAPID with TestSignDefine but I get some plots only for the newer version.
And now I am a little bit confused. Does it work only for RW 6.05 or maybe each version has different numbers of test signals.I would really appreciate some help with this.
Test signals for standard manipulators are confidential and only for ABB internal use.
