following the restart of our IRB2400 M2000/S4C, many thanks Iowan... on trying to synchronize all axis i receive a error message.
Error 39217
Drive unit unable to supply ordered current, due to low DC-voltage or broken motor connections. Drive unit joint: irb_5.
Measured DC-bus voltage: 374.00 (v).
all axis other than 5 move OK. when 5 is moved it travels a short distance then stops with the above message. Is the fault likely to be the wiring to the motor failing? a defective axis drive motor? or software cabinet related? are there any tests i could perform to localize/identify the issue and how do you access the wiring in the robot arm?
Any help would be much appreciated.
Cheers Steve.
