Hi everybody.
I want to ask if there is a way to connect from my office to the TP of a robot which is at the factory.
Does the robot need any spacial software option?
Thank you in advance.
Hi everybody.
If you're on the same network, go to the robot's webpage and click on IPendant ECHO
Install Roboguide on PC in network with TP
By Internet use teamviewer for remote monitoring TP on PC in network with robot
The Remote PC iPendant option will allow you to login to the TP remotely from your computer and make changes like you were there with the robot. You can even jog it. You can't cycle power though.
You'll need Internet Explorer to do that though.
Important to clearify what you REALLY want:
- Checking values of Registers, PR's, I/O can be done via Web server and is very very easy.(Not paid option)
- Only monitoring can be done bij Remote Monitoring, which you will find in the advanced options of your manual. As already said, you need IE for that and it is quite a bitch to get it up and running. (Not paid option)
- Remote control is paid option and mentioned already
When i am at the factory, i can use IE and ECHO at the webpage of the robot, to see the teach pentant. I need to have the same option when I am at my office!
VPN into your factory. Should work as normal then
