Interrupt in Motion
  • daxter
  • September 29, 2017 at 9:08 AM
  • daxter
    Hello to all, sorry for my bad english...
    I have a problem using an interrupt.
    On the robot I have a system of anti-collision, if It intervene, I must stop and go backward.
    This is the function:
    INTERRUPT DECL 4 WHEN $IN[27]==TRUE DO ROADAFTERCOLLISION()
    INTERRUPT ON 4
    FOR contaPunti=1 TO (totalLandingPos)
    CRASH_POINT=contaPunti
    XAUX_GOING_PTP=landAxisPos[contaPunti]
       ;FOLD PTP AUX_GOING_PTP Vel=100 % AUX_GOING_PTP;%{PE}%R 8.2.20,%MKUKATPBASIS,%CMOVE,%VPTP,%P 1:PTP, 2:AUX_GOING_PTP, 3:, 5:100, 7:AUX_GOING_PTP
       $BWDSTART=FALSE
       PDAT_ACT=PAUX_GOING_PTP
       FDAT_ACT=FAUX_GOING_PTP
       BAS(#PTP_PARAMS,100)
       PTP XAUX_GOING_PTP C_PTP
       ;ENDFOLD
    ENDFOR
    INTERRUPT OFF 4
    So i have an other function, in another file .src:
    DEF RoadAfterCollision()
    INT ContaPunti
    ;----- TEST
    ;XAUX_POINT_PTP = $AXIS_INT
    ;BRAKE
    ;WAIT SEC 0.5
    ;RESUME
    ;----- TEST
    ;FOLD INI;%{PE}
      ;FOLD BASISTECH INI
        GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
        INTERRUPT ON 3
        BAS (#INITMOV,0 )
      ;ENDFOLD (BASISTECH INI)
      ;FOLD USER INI
        ;Make your modifications here
      ;ENDFOLD (USER INI)
    ;ENDFOLD (INI)
    ;===== ROAD AFTER COLLISION ======
    TEST_IT=TRUE
    FOR ContaPunti=1 TO (CRASH_POINT-1)
    XAUX_POINT_PTP=departAxisPos[CRASH_POINT-ContaPunti]
    ;FOLD PTP AUX_POINT_PTP Vel=100 % AUX_POINT_PTP;%{PE}%R 8.2.20,%MKUKATPBASIS,%CMOVE,%VPTP,%P 1:PTP, 2:AUX_POINT_PTP, 3:, 5:100, 7:AUX_POINT_PTP
    $BWDSTART=FALSE
    PDAT_ACT=PAUX_POINT_PTP
    FDAT_ACT=FAUX_POINT_PTP
    PTP XAUX_POINT_PTP C_PTP
    ;ENDFOLD
    ENDFOR
    WAIT SEC 5
    RETURN
    END
    When my input 27 goes to 1 then the robot goes wrong and tells me that there is a programming error. I release the interrupt while the robot is moving, I tried to add the BRAKE and RESUME instructions, but without success.
    Do you have any idea?
    Thanks a lot in advance and if there are some unclear points tell me as well. Thanks again
    SkyeFire
    1,039
    9,375
    • September 29, 2017 at 7:15 PM
    Programming error? WHAT programming error, SPECIFICALLY? Does the error occur during compilation, or execution?
    First thing to do, is remove everything from RoadAfterCollision() from the ;FOLD INI to ;ENDFOLD (INI). You don't want that stuff in an interrupt-called program.
    Interrupt routines cannot end with RETURN.
    BRAKE and INTERRUPT OFF 4 should be at the top of the interrupt routine. RESUME should be at the end.
  • hermann
    404
    2,595
    • September 30, 2017 at 12:04 PM
    You should start a search in the forum for "RESUME" and You will find many examples.
