KAREL programming variables file
  • nerd484
  • September 28, 2017 at 8:29 PM
  • nerd484
    21
    I am rather new to KAREL and I was advised by fanuc that a good approach to a more complex karel program is to split the program into separate files. One file is the main program with references to the other project files, one program for routines & functions, and one program for variables. The issue I am having is when I try to create a new karel program for just the variable declaration. When I try to compile a program file with only variable declarations I get a compilation error stating that the program must have a begin statement. If add in a begin statement with no code or just simple variable initializations, it will compile ok; but, when I reference the variable program from another project file with %include K_variables, I get an error that says there is an error with the VAR command in the variable file and that an ID is expected. Should I even be compiling the program for variable declaration? What is the proper way to create and reference a file for just variables?
    My variable file is something like:
    Program K_Vars
    VAR
    int1:INTEGER
    int2:INTEGER
    END K_Vars
    The main program would look like this:
    Program k_Main
    %INCLUDE K_Vars
    Begin
    do stuff here...
    if(int1 = 0) THEN
    do more stuff...
    ENDIF
    END K_Main
  • DPKG
    18
    • September 28, 2017 at 8:52 PM
    When you %INCLUDE something, the contents of the included file will be merged with the main file, replacing the %INCLUDE directive.
    Your K_Vars.kl should become:
    VAR
     int1:INTEGER
     int2:INTEGER
    Then your k_Main.kl will compile correctly.
    Beware the %INCLUDE order and position, global variables declarations are on top, routines must be defined before beeing used and so on.
  • nerd484
    21
    • September 28, 2017 at 9:02 PM
    Great! I got it now. Thanks for the help! :yesyesyes: :dance2: :bravo:
  • Tran21
    24
    • June 15, 2022 at 5:53 AM
    I tried the codes above with no sucess, can someone please explain.
    PROGRAM k_Main
    %INCLUDE K_Vars
    BEGIN
    --do stuff here...
    IF(int1 = 0) THEN
    --do more stuff...
    ENDIF
    END K_Main
    File name K_Vars.kl as below:
    VAR
    int1:INTEGER
    int2:INTEGER
    Robogiude V9(Rev N)
    Errors after build all:
    Set Extra Includes
    \TestInclude\SubProgs\k_vars.kl(1)
    1 VAR "PROGRAM" expected
    1 VAR Id expected
    2 int1:INTEGER "BEGIN" expected.
    2 int1:INTEGER ";" or new line expected.
    2 int1:INTEGER Invalid statement or "ENDxxx" or "UNTIL" expected.
    3 int2:INTEGER Invalid statement. ";" or new line expected.
  • Tran21
    24
    • June 15, 2022 at 2:26 PM
    Correction.
    %INCLUDE SUBPROGS\K_Vars
    Still having same errors after build all
  • Tran21
    24
    • June 15, 2022 at 2:36 PM
    Summary: All files built successfully as settings below.
    Same errors if K_Vars.kl is checked along with k_main.kl.
    Which is correct?
  • Tran21
    24
    • June 15, 2022 at 2:43 PM
    Ran k_Main,kl and got:
    (K_Main,5) Uninitialized data.
  • hermann
    412
    2,629
    • June 15, 2022 at 9:36 PM
    Quote from Tran21
    --do stuff here...
    Here is the problem, but nobody can tell you what exact, because we don't know what stuff is done. :winking_face:
  • Tran21
    24
    • June 15, 2022 at 10:57 PM
    Okay, thanks very much.
  • Tran21
    24
    • June 16, 2022 at 6:14 PM
    Hermann,
    My apology, I found my problems.
    In general, the sequence of creating and building Karel using %INCLUDE files in robogiude confused me.
    After trials and errors, learning the software, I got my codes working.
    Thanks.
