Karel - Hide global variable from the DATA screen
  • malain
  • September 28, 2017 at 4:32 AM
  • malain
    14
    63
    Is there a way to hide global variable from the DATA screen of the TP.
    Example :
    PROGRAM test
    VAR
    Var_A : INTEGER --I want this one can be access from the DATA menu of the TP
    Var_B : INTEGER -- I don't want to show this one in the DATA menu of the TP, but need to be global
    BEGIN
    --blablabal
    END test
  • DPKG
    18
    • September 28, 2017 at 9:21 PM
    You can try something like:
    PROGRAM hiddenvar
    %INVISIBLE
       VAR
    BEGIN
    END hiddenvar
    PROGRAM test
       VAR
            Var_B FROM hiddenvar : INTEGER     -- I don't want to show this one  in the DATA menu of the TP, but need to be global
    BEGIN
        --blablabal
    END test
    Var_B will be stored in hiddenvar.vr and, since hiddenvar.pc is %INVISIBLE. it will not be shown anywhere on the TP.
    It will serve normally as a global (external) variable in test.pc.
  • malain
    14
    63
    • October 4, 2017 at 3:52 PM
    WOW... that make sense, I will give it a try!!!!
