Hi all,
Does KUKA have option similar to SoftMove (ABB)?
http://new.abb.com/products/ro…/machine-tending/softmove
Hi all,
There is an option called KUKA.VectorMove. On the surface it looks similar to the ABB description...
good luck
vds
I don't know how to have a kuka robot applying a determined force along a vector, but if you just neet to set one or more "soft" axes, you can apply a torque limitation:
I wrapped the KUKA functionality in this function:
GLOBAL DEF limit_torque(ax:IN,range:IN)
INT ax
REAL range
DECL TorqLimitParam limits
IF range>0 THEN
limits.monitor = #OFF
limits.max_lag= 90
limits.max_vel= 600
limits.lower = -$TORQUE_AXIS_MAX[ax]*(range/100)
limits.upper = $TORQUE_AXIS_MAX[ax]*(range/100)
SET_TORQUE_LIMITS(ax, limits)
ENDIF
END
And to make axis 1 pushable by hand for 10 sec, you can do:
BE CAREFUL WHEN LIMITING THE TORQUE OF OTHER AXES!
diglo
