Hi everyone!
Our existing setup consists of 2 M10-iA Robots that are side by side and used for arc welding. There is also 2 manipulators on a H-Frame.
On Pendant 1 in G1 is Robot 1, G2 manipulator 1 and G3 manipluator 2. On pendant 2 is Robot 2.
Online, Robot to Robot Communication is used so that Robot 2/Pendant 2 uses a "Wait DI 40 = On" to wait for the manipulator to move and then once it has stopped a "DO 40 = On" is used on Robot 1/ Pendant 1.
This works fine in reality and Robot 2 wont move until the manipulator has given it the signal.
However in Roboguide The program on Pendant 2 gets to its wait for DI line and stays there whilst the program continues on Pendant 1.
I have tried using 'Logic Simulation Assistant' but the DI/DO's are just bypassed.
In the Run Configuration I have also tried it in 'Auto' using an RSR but get the following error.
"The production start UOP signal ("UI[xx]") is not defined for controller..." So i am not sure if this is the reason why?
Any help is greatly appreciated!
p.s. I am very new to programming and a lot of the problems I have to solve by myself so expect a few more questions over the coming weeks/months.
