Bad Shut down Encoder Cable failure error etc
  • Ceta11
  • September 14, 2017 at 8:50 AM
  • Ceta11
    Guest
    KUKA KR210, with KRC2 KSS 5.6.10, WinXPe
    Could this happen after a bad shut down ? Probably files are badly corrupted if I did issue Shut Down Cold Boot and accidentally flipped switch off ahead.
    How do I recover ?
    After Shut down robot was sitting, 3 days later this message is what I get on image when I power up.
    Cannot master because robot doesn't move (see image). I do not have spare hardware to test, i.e.: cables or DRW (DRC) card, etc.
    This happened after everything was working fine, no issues whatsoever with hardware, no bumps or cable accidents. All major cables are in great shape, fuses all OK. DRW (DRC) card shows LED green and red correct. Cabinet is very clean inside, everything running and LED are all correct.
    Run the DSE-DRW app and everything looks fine, except sometimes RDC Communication show all Axis fine, other times all show 0000, or 1 or 2 axis 0000.
    I cannot recover from this... Right now my only hope is reinstalling KSS (which is faster than other options), tried restoring archive.zip but did not work. Batteries are fully charged and 3 months old or less (12V but 5 Amps instead of 5.4A).
    Any help will be greatly appreciated. Thanks.
    Images
      • 1.39 MB
      • 1,076 × 808
      • 93
      • 745.97 kB
      • 1,018 × 615
      • 86
      • 1.11 MB
      • 1,080 × 808
      • 68
      • 601.95 kB
      • 967 × 615
      • 50
    Files
    Screen Shot 2017-09-13 at 11.14.08 PM.png_thumb 31.28 kB – 188 Downloads Screen Shot 2017-09-13 at 11.46.52 PM.png_thumb 18.92 kB – 180 Downloads Screen Shot 2017-09-13 at 11.47.10 PM.png_thumb 24.37 kB – 178 Downloads Screen Shot 2017-09-13 at 11.47.25 PM.png_thumb 18.87 kB – 176 Downloads
  • panic mode
    1,296
    13,136
    • September 14, 2017 at 2:25 PM
    blown fuse?
  • Ceta11
    Guest
    • September 14, 2017 at 4:12 PM
    I will check again, did no see... but a double/triple check will tell. Thanks.
    Edited once, last by Ceta11 (September 14, 2017 at 4:35 PM).
  • Ceta11
    Guest
    • September 15, 2017 at 12:36 AM
    No luck, checked continuity with multi on all and no blown fuse.
    ??? am lost.
  • Ceta11
    Guest
    • September 18, 2017 at 4:38 AM
    Did reset the MFC card and DSE, nothing different. All the LED are green.
    A lot of reading here and one opinion tell me that the RDC board could be the culprit.
    Upon start the lights flash red and solid green, then stops and show solid red and green. This is the correct behavior according to Manual.
    Could this card still be faulty ? wish I had one to swap... but nothing near.
    What has been your experiences ? Thanks a lot.
    Edited once, last by Ceta11 (September 18, 2017 at 4:47 AM).
  • dblbeard
    25
    • October 1, 2017 at 6:39 PM
    Under the DSE Diagnostics(one of the pictures above). Open it up again then look below at the soft keys you will see
    Live display or Continuous Display, select this.
    Then watch the different axis numbers in communication, you should see each one of them changing. That is only ones that have motors.
    If the RDC is functioning properly and you have a good RDC you should see the numbers changing slightly.
    As you said before, if you are showing all "000"on more than axis I would start with changing the RDC and or the RDC cable.
    I would only change one at the time.
  • romany4
    5
    • February 6, 2020 at 6:53 PM
    Can somebody help, please!
    I have same situation.
    102 Encoder failure cable fault is for all axes, an also I have message 106 "perform mastering" for all axes.
    Those errors appeared in working process without power failure. Robot just stoped.
    I exchanged a cable for encoders (forgot number) from another robot. Did cold start. But faults are same.
    RDC card after loading has solid green and red leds. Could it be problem in cabinet board? I have one more robot. Could I borrow those cards and try it on broken robot without harm to working?
    Thank you!
  • panic mode
    1,296
    13,136
    • February 6, 2020 at 7:21 PM
    whenever messages complain about same thing for all axes, chances are that something common is not right.
    both red and green LED on RDC2 should be on.
    feedback chain includes RDC, RDC interface X31, data cable X31-X21, cabinet interface X21, Cable from X21 to ST4, ST4 interface, DSE and MFC.
    as stated before DSE-RDW status can be checked on HMI, there is a tool for this.
  • Stipe Sutalo
    17
    • April 27, 2022 at 10:26 AM
    Hello to all,
    romany4 did you find solution for your problem?
    I have same problem. We changed cable and RDW card and we have same thing on all axis.
    panic mode do you have some advice what to do?
    Thank you in advance!
  • panic mode
    1,296
    13,136
    • April 27, 2022 at 1:56 PM
    Read pinned topic READ FIRST, start new topic, post relevant details...
  • halo4334
    • November 18, 2022 at 8:11 PM
    • #11
    Merhaba krc 2 A3 encoder cable hatası var robot hareket ettiremiyorum her yere baktım ama çözüm bulamadım yardımcı olurmusunuz
    Hello, there is a krc 2 A3 encoder cable error, I can't move the robot, I looked everywhere but couldn't find a solution, can you help?
  • panic mode
    1,296
    13,136
    • November 18, 2022 at 9:01 PM
    • #12
    solution is simple - replace defective part.
    there are only three possibilities: motor, RDC or the cable between them.
