I use IRVISION (sony camera) and I want to display the image of the camera on a user interface (like Intouch). How can I get the live image to the interface? Any Idea?
I dont know what Intouch is exactly, but you can log into the feed through a laptop to view it via iRVision Runtime through Fanuc's webpage. If you have similar access via Intouch it should also work....I would think.
Are you familiar with accessing Fanuc's webpage?
Intouch is a HMI software from Wonderware.
Yes intouch can propably display the iRVison runtime (good idea, thanks). But I just need the picture, not all the button and information about the pieces. I found that I can log image on the MC card... but is there a way to acces the MC card files. Example : IPADDRESS/MC/file.png
So here were I am (if someone need this information)
So yes I test it by using the web acces in Intouch and the result is not exactly what I need. I don't need the vison button and information about the pieces.
I also try to retreive the image from the MC card by using GET of the FTP command in windows and the approach seems good, but I will need to built a little program (maybe a batch file) that will:
- Connect to the robot (FTP xxx.xxx.xxx.xxx)
- Get the listing of the picture name (cd \mc:\vision\log\<the date>)
- Spot the last file (dir .........and some work to do.. this "dir" doesn't have all the option of the dir in windows)
- Copy this file locally on the PC (binary and get filename.abc
- Close the connection (close quit exit)
- Give to the HMI the path of the local file (some work to do here)
It will work, but I was hoping a easier solution. So if someone has something else to suggest, i'm ready!!!!
Malain,
Did you make this work? I'm trying to make something similar work and this information would be very useful.
EVargasT
Send malain a personal message if you need a faster response
Hi guys,
I put the "IRVison Fanuc controller web page" into my Intouch interface. I view some button (zoom, pan, etc), but I can live with it.
If you found better solution let me know.
thank
I would also like to show image from iRVision on HMI.
I enabled logging to UD1 (my MC is not working), but I'm just getting D:\VISION\LOG\Y18AUG02\SUB00000\LOG00000.VL and noting else to USB.
Is there a problem with USB or there is something else wrong?
EDIT: I found out that image logging must be enabled in vision process.
