Connection by Profibus KRC2 and S7-1200
  • Hello. I have robot KUKA (KRC v.5.4.14, KR200 2 CPT S C2 FLR ZH06, Windows XPe) with Profibus card CP5614A2 and PLC Siemens 1212C with commutation module CM1243-5. I need to set up the link betwin them and send some bytes. PLC-Master, KRC-Slave.
    In TIA Portal i'm install GSD file KUKA for CP5614A2 as slave and config it with Profibus adress 3, PLC adress- 2, also there in configuration CP i added 1 byte input data and 1 byte output data.
    In KUKA i configured files iosys:
    [CONFIG]
    VERSION=2.00
    [DRIVERS]
    PBMASL=11,pbmsInit,pfbmsdrv.o
    [PBMASL]
    INB64=127,0,x1
    OUTB64=127,0,x1
    and pfbms:
    [CP_5613/14]
    DEBUG=1
    LOGFILE_PATH=log/pfbms.log
    ERROR_TEXT=German
    FORCE_RESET=0
    OLD_ERROR_DB=0
    [MASTER]
    MASTER_USED=0
    DATABASE_PATH=init/
    FIRMWARE_PATH_A1=drivers/FW_5613.bin
    FIRMWARE_PATH_A2=drivers/FW5613A2.bin
    WATCHDOG_TIME=3
    MAPPING_USED=0
    MAPPING_PATH=init/
    ;DEACTIVATED_SLAVES=
    [SLAVE]
    MODUL_USED=1
    MODUL_ADDRESS=3
    START_TIME=60
    ERROR_ACTION=1
    STANDBY=1
    SLAVE_TIMEOUT=0
    CHECK_CONFIGURATION_DATA=0
    ACCEPTABLE_INPUT_LENGTH=244
    ACCEPTABLE_OUTPUT_LENGTH=244
    IO_DATA_BASE=0
    CONSISTENCE=0
    After restart and reconfiguration drivers in robot there is error of reading driver CP561DRV and message ERROR IN SLAVE circuit:
    LOG file:
    On the PLC flash BF(bus fault)
    what am I doing wrong? :help:
    Edited once, last by Serj7891 ().
  • Hi Serj7891,
    Did you managed to configure described connection ??
    I need to establish connection between Kuka KRC2 with CP5614 A2 and CPU 1510SP-1PN with CM DP module.
    Could you give me some ideas how to do it ?
    Thanks,
  • Estimado Sergio, pudo Usted solucionar la comunicación PROFIBUS entre el KRC2 con la 5614 A2 y la CP1243.5 de la línea 1200 de Siemens?. Muchas gracias
