Good day! REALLY need help!
Problem: don’t working «Motor power ON» after dead RAM battery replacement at FS003NFD70 robot.
History of the problem:
Fully discharged backup battery (on 1KA board, 0.15V measurement instead of 3.6V normally) corsed red «Kawasaki» logo hanging on white screen at Teach Pendant (the robot was not used at the summertime).
Applied treatment course:
– RAM lithium battery was replaced (coursed the same starting window with «Kawasaki» logo at Teach Pendant)
– «Initialization window/0 NO» was choosen (using switch 8 of 1KA board to ON). (Resulted in: AC primary power off [System data sum check error => Set initial value]
(D2023)Failed to load arm data
– «Initializaition window/1. Initialization of the system» was choosed
(D1017)Download error of servo data
(D1016)The servo data file does not include available servo data
(E0903)Check sum error of system data
– Backup .as file was loaded (via notebook TCP/IP communication, the backup file was saved several months ago from just that robot).
While loading several dialogs with (Strongly recommended… skip/force – force choise was choosen). That coursed following errors:
(D1507)AC primary power off
(E1030)Encoder data is abnormal
All errors have been reset (Check sum error by CHSUM AS command), but NO «Motor power ON» is since available!
– CPU error occurred while AS command «save r2E0809.el»:
>save r2E0809.el
Saving… (r2E0809.el)
Network configuration data
ROBOT DATA
OPERATION INFORMATION DATA
SYSTEM DATA
AUX DATA
(D0001)CPU error.(PC=37EA7BF6)
(D0001)CPU error.(PC=A639DE3B)
After reloading the controller the file was normally saved by the command:
>save/elog r2E0809
Other functionality (DIO signals, Teach Pendant functionality and so on are just fine, but no ability for the MOTOR POWER ON)
More about the robot:
KRG-DEU
FS003NFD70
S/N 0496
Date: 2008/2/14
AS Software: AS-R1D0021F
Servo Software: SV-R5000007
The robot was good working this spring with no problem.
The robot’s neibor is another one – good working. It’s just the same, has s/n 495 and AS, servo software – absolutely the same.
If is it possible to reinstall AS and servo software? How to do that? Or maybe there is another simplier solution.
Thank you a lot for your answer !!
With respect,
Kulakov Boris
