ConveyorTech issue
  • Palle
  • July 1, 2009 at 3:24 AM
  • Palle
    Guest
    Hi all,
    Got a KR 15 SL , with UserTech,ConveyorTech installed and I use the resolver option.
    Aim is to sync the robot with a linear conveyor, and execute coordinates supplied by a vision system.
    Situation:
    I have followed the documentation.. Measured the geometrical data with the program "CONV_MSR"..
    Measuring the conveyor, checking the “CAL_DIG” all went according to plan. After measuring the part frame which is BASE_DATA[11], things turned to worse:
    BASE_DATA[11] did no get defined by the "CONV_MSR", then I tried to measure the BASE_DATA[11] manually using the 3 point method that worked just fine.
    Made a small program based on the conveyor template, using 3 points with BASE_DATA[11] as ref for conveyor 1 movements group1.
    Movements started promptly after the "WAITDIST" was reached, but the movements where not in sync with the conveyoer.
    I get no error or warning messages
    I am puzzled by what is wrong.
    * Why CONV_MSR is not able to write data to BASE_DATA[11]
    * why my movements aren't in sync with the conveyor
    Since these are interlinked it very likely to think that my problem originates from the same fault...
    Help please :help:
    Best regards
    PF
  • Palle
    Guest
    • July 8, 2009 at 7:40 PM
    ok I got it all wrong...
    Thanks anyways
  • Tuipveus
    13
    • September 28, 2009 at 7:36 AM
    And remember to be extremely carefull with advance run, since I have notice that it doesn't always go according $advance with conveyor tech. Sometimes very rarely it doesn't work and caused crash. Stopping the motion after advanced run solved the problem in my case.
  • RicardoPimenta
    Guest
    • October 30, 2013 at 4:42 PM
    Have you solved the problem? i have the same one!!
    Thanks in advance
  • ezzine
    21
    • July 12, 2016 at 12:33 PM
    didn't u got the problem mdr:unknown devicename when working on the conveyor tech ??
  • the leg
    643
    • July 15, 2016 at 9:30 AM
    Quote from ezzine
    is this on software version 8.3.17 SP3 i think it is as if it is its a software bug and needs an upgrade
  • ezzine
    21
    • July 15, 2016 at 11:17 AM
    No it 8.5 ithink ....now have a new problem after ive resolved that one it is mdr : changing device state fom error to inzialized unauthorized
