Hi to all!
I have some questions regarding the variable JBF.
I'm making a program using position registers, basically i add a sensor so while the sensor is active the registry add 1mm on Y. When the sensor stop sensing the robot stops to perform other activities.
At the beginning i had the error:
CPMO-010 SERVO2 Cycle power:JBF size (G: %d^2)
I found that changing the variable: $CP_PARAMGRP[1].$JBF_SIZE it can solve my problem. I changed the variable to the double and indeed it solve the error running the program.
But....
Does anyone can explain me what happened? what is the consequence to increase this memory variable? And in fact what exactly is?
