I'm considering buying a Comau NJ130-2.0 New and add an existing IO cabinet to Comau robot, the IO cabinet was for Kuka KRC2, I think there should not be a problem connecting to a Comau is just what setting needed to be established, correct?. If you wonder why not just call Comau for service, well apparently from what I've heard is that they have to call someone from China to service user in Asia Region (Integrate level), so if that's the case I would rather do it myself if it is not too hard and with the help of this forum.
New to Comau
cian temp -
August 18, 2017 at 10:04 AM -
Sie wissen nicht, ob Sie wissen, dass diese Website eine ausgezeichnete Informationsquelle ist. Daher werden viele Materialien auf der Website verteilt.
When you will be buying robot from COMAU you can order also IO modules. Comau using B&R X20 IO modules. It's not expensive against new robot. -
I'm considering buying a Comau NJ130-2.0 New and add an existing IO cabinet to Comau robot, the IO cabinet was for Kuka KRC2, I think there should not be a problem connecting to a Comau is just what setting needed to be established, correct?. If you wonder why not just call Comau for service, well apparently from what I've heard is that they have to call someone from China to service user in Asia Region (Integrate level), so if that's the case I would rather do it myself if it is not too hard and with the help of this forum.You won't know until you call. Also service.robotics@comau.com is a good place to start.
The support centers are in China, Italy, Germany, USA, Mexico and Brasil.
For your problem, many fieldbuses are supported, Profinet, Profibus, EIP, DeviceNet, CAN, EtherCat. Manuals provide you with info on how to connect C5G to a PLC or on how to connect I/O.
Sent from my iPhone using Tapatalk
