Robot don't wont read program
  • Alex_Moser564
  • August 16, 2017 at 10:46 AM
  • Alex_Moser564
    37
    I've created simple program for KUKA in 3-rd party Proto-G but my robot don't see coordinates of it.
    It see only ptp home at start and at the end.
    The files are attached.
    The system is:
    KR C V4.1.7 SP8
    GUI vershion: V KR C1 V3.3/V4.1
    How to fix this?
    Files
    proto1.dat 58 Byte – 15 Downloads proto1.src 7.26 kB – 24 Downloads
  • Fubini
    284
    1,906
    • August 16, 2017 at 11:57 AM
    Your last program line
    PTP HOME VEL=5%
    is no valid KRL statement. Maybe you meant only
    PTP HOME
    Fubini
  • panic mode
    1,300
    13,143
    • August 16, 2017 at 8:50 PM
    PTP xHOME
  • hermann
    412
    2,629
    • August 17, 2017 at 8:20 AM
    Fubini has the right hint and:
    HOME = {AXIS: A1 -90, A2 -90, A3 90, A4 0, A5 90, A6 0}
    should be:
    HOME = {A1 -90, A2 -90, A3 90, A4 0, A5 90, A6 0}
  • panic mode
    1,300
    13,143
    • August 17, 2017 at 3:45 PM
    yes but name "HOME" is just facade used in inline forms. such variable name does not exist. if you want to program with inline forms you can enter "HOME" as point name but if you are typing commands by hand, you must prefix it with "x".
    just open single variable monitor and test it or - try to save program and see if it compiles.
  • hermann
    412
    2,629
    • August 17, 2017 at 4:03 PM
    Have a look onto the source.
    In line 7 the variable HOME is declared. So it is ok to use it.
    Anyway it is a bit confusing and may be man should not do something like that.
  • panic mode
    1,300
    13,143
    • August 17, 2017 at 4:42 PM
    my bad... did not see that :pfeif:
    not practice i condone...
  • Alex_Moser564
    37
    • August 20, 2017 at 2:44 PM
    Thanks for your post.
    Realy problem was not in that and also not in home and not in program.
    Realy program was in compiling the program to the memory of the robot.
    After recompiling program it starts to execute.
    Thanks for your attention to my problem a lot.
    At last we have configured our robot to work. And problem was wo mere!!!
