i think i got it.. try it out. it works on Roboguide and on a real Robot
Is this another modification of the .pc file like I did, or did you manage to replicate the source code?
I think i replicate it. I wrote it in roboguide. It seem to work and I tried it on diverent controller..
Would you be willing to share the source code? I am curious on how this works.
now problem, I will send to you tomorrow.
Hi! I've tested it and it works just fine! Can you please share the source?
I modified it a little bit because it would not show the "0" when the code starts with "0". now it does. it has also the .kl file
Display MoreWell, JT hasn't logged in in 2 years, so I have my doubts that he will see your request.
However, even without the source code, you can hex edit the karel file to make it work on v9 controllers.
This is what I did, and I tested it with v9.30 Handlingtool, and it works.
Modified .pc file is attached.
Im wondering what part of the pc file you modified to update the version? I opened the HEX file with ultraedit however I coulnd´t find any part related to the robot software version
I modified the byte at position 0A from 27 hex to 29 hex, and that made it work.
Figured out what position to modify by compiling a blank program on v8 and the same on v9 and comparing them. Comparison tool was ultracompare.
thanks for the update!! I appreciate it.
not sure if you were also asking about the user/pass portion of the original PC, but it can be recreated utilizing $password.$num_users and $passname.$name/$password
hope this helps.
hi, would you guys be willing to reiterate a bit here on password removal? I purchased a used fanuc M16i robot RJ3iC controller and cannot seem to master, change variables, load files or anything other than jog due to the password set for installer. Thanks
MAGPRO, you still need help with this?
Hi, thanks for this, I will try it
