Does anyone know if you can directly communicate with a EtherCAT COE interface? or is there a gateway needed? KRC4
CANopen interface?
TickTack -
July 31, 2017 at 6:53 PM -
as far as i know only few selected communication modules are supported (DeviceNet and ProfiBus).
anything else will not work directly and - that includes Canopen, RS232, RS422, RS485 etc. -
Thanks for the info. It seems like when I import the device xml description file, it can determine the manufacture and communication protocol needed. But then crashes WoV, is this a sign it won't work even though it got imported?
[size=4]EL1xxx - digital input modules (most are supported)[/size]
[size=4]EL2xxx - digital output modules (most are supported)[/size]
[size=4]EL3xxx - analog input modules (many are supported)[/size]
[size=4]EL4xxx - analog output modules (many are supported)[/size]
[size=large]EL5xxx - specialty modules (some are supported, like encoder etc.)[/size]
[size=4]EL6xxx - communication modules (only FEW are supported)[/size][font=verdana, arial, helvetica, sans-serif][size=4]in fact "few" is only 6...[/size][/font]
[font=verdana, arial, helvetica, sans-serif][size=4]two of them are bridge modules:[/size][/font]
[size=4]EL6692, EL6695, [/size][size=4]and others are DeviceNet and ProfiBus Maser/Slave modules[/size]
[size=4]EL6731, EL6731-0010, EL6752, EL6752-0010[/size][size=4]i am not aware of anything else from EL6xxx range.[/size]
