Hi everyone,
Anybody who knows the error code which likes "MIGE - XXX" of Laser Tracking.
I want to know why this occurs and how to deal with it!
I guess that the MIGE means MIG-EYE.
If you know,please tell me.
Thank you!
Best regards!
Jonson
Hi everyone,
Thank you!
Best regards!
Jonson
Which error code do you have?
Looks like comm error.
Check if you added IP of vision system to Host screen. Host name must be SR. Look at attachment.
Thank you for your reply.
My setting is the same as photo. I have no idea!
Do you have all required options installed on controller?
Which laser tracking system will you use?
Yes, of course!
The robot is not always with this error.
This error occurred by accident!
Maybe you have some interference issue. Did you follow grounding instructions for laser tracking system?
All components should be grounded to one point, electrical cabinet mounted using insulating pieces, special communication cable that is grounded on one side, ...
Hi.
I have a problem with MIGE 058.
Please help me.
Thank you.
MIGE–058 ABORT Segment buffer index overflow
[Cause] Internal error.
[Remedy] This is an internal error. Report it to our FANUC service representative
I believe this is caused by wrong setting of $SR_SETUP.$UPDATE_TIME parameter. Controller is getting to many information per tracking length.
You need to calculate correct update time value for all of your welding (tracking) speed ranges. Formulas are in ArcTool manual.
I usually calculate this parameter before each weld or when we use adaptive welding I calculate this parameter based on min and max welding speed.
Does anybody has any experience with MIGE 008?
