Minimizing error values with iRVision
  • romanzo
  • July 24, 2017 at 2:10 PM
  • romanzo
    21
    I am currently in the process of calibrating 8 cameras with 2 robots using the Robot-Generated Grid Cal. Tool. Each robot has 4 cameras associated with it and they are all set up in a horizontal line. I have an extension tool on my EOAT so the robots can reach all of the cameras. I have got them all calibrated with decent error values. My minimum error values are all under 1. My maximum error value differs a little more which is discerning. The maximum error ranges from around .8-2 on Robot 1, and around 1-2.1 on Robot 2. I'd like to get the maximum error value on all of my calibrations to below 1 if possible. Any tips on how to do so would be greatly appreciated. Thank you.
  • Nation
    Typical Robot Error
    556
    1,937
    • July 24, 2017 at 5:56 PM
    You can delete the outlier data points in the cal grid data. That should reduce the error somewhat.
    Also, make sure you are running the IRVBKLSH karel program before each calibration point (if you are not using the autocal utility, it does this automatically.).
  • andreic
    25
    284
    • July 25, 2017 at 12:55 PM
    And how that translates to you accuracy in mm?
  • Nation
    Typical Robot Error
    556
    1,937
    • July 25, 2017 at 2:46 PM
    I assume you are asking about the IRVBKLSH program.
    IRVBKLSH cancels the backlash in the robot's arm gear train by preforming a small move. Once the backlash has been canceled, the arm's real position better represents the calculated position.
  • romanzo
    21
    • July 25, 2017 at 4:41 PM
    I am using autocal & it runs the IRVBKLSH program. My max error value isn't horrible, I think my worst is 2.1pix. But I'd like to get them all closer to 0. I was just curious if maybe anybody knew of any ways to reduce this. I have tried a few things like messing with the exposure of changing the intital position around. Nothing seems to really get it lowered though. I am starting to think maybe it is a little too shaky on some of the far points since the target is on a 3 foot pole extended off of the EOAT.
    Edited once, last by romanzo (July 25, 2017 at 5:16 PM).
  • pdl
    272
    1,549
    • July 25, 2017 at 5:16 PM
    What's the resolution of your camera?
    You'll defiantly wasn't as stiff a setup as possible.
  • romanzo
    21
    • July 25, 2017 at 5:28 PM
    I have the resolution set to 1280×1024 at the moment to allow the largest field of vision.
Users Viewing This Thread
  • 1 Guest
